Material test understanding
Please explain the different boxes, which one is best?
Longer Ray5 20w
Show a picture of the result from the laser, and maybe we can judge it from there.
You are using preview… it shows where it will lase, not the results on your material, which it has no knowledge of.
As @bernd.dk advised, show us the results on the material..
:grinning_cat:
Thanks, I know, I was unclear. I’m wondering about the fact that there are different thicknesses of paint in the different boxes. Should that somehow indicate that that particular box has the best setting.
Yes, it´s a preview for white cheramic. I was just curios about the different size of the red colour. We can stop here.
I will explain the material tests a little bit anyway.
The idea is that by setting different parameters in the system for a test, you can find the most suitable result. You are probably surprised that everything is black in the preview window, but if you zoom in a lot on this preview window, you will see the difference. Once you have found a reasonable range for power and speed (or line spacing), you can refine the settings further to achieve perfect results by inspecting the results after laser processing.
I have done many tests and saved the physical results, so I can always review the optimal settings for a specific task/material.
I hope you can also use your tests in a similar way.
