still learning. ruida controller.
can someone explain the correlation between these two settings?
the effect that they have during cutting?
offer suggestions as to where to find such info?
Min Power can be thought of as âcornering powerâ - itâs what the controller uses when itâs running at or below a speed threshold called âStart Speedâ in the controller itself (you can change this in the machine settings, and itâs usually 10mm/sec).
Basically the controller uses Min Power when itâs running slow, then when you pass the âStart Speedâ and ramp up to your chosen speed value, it ramps the power up from Min to Max at the same time.
Normally you set Min to just above the firing threshold of the laser tube if youâre doing surface marking (vector engraving along the lines, instead of a fill). Youâd set it to the same as Max power if youâre doing slow cutting, or fills.
