Measurements out
Hi. When I put in measurements the height is coming out at 8 mm longer. Hope someone can help me solve this. Thanks
The usual cause is having inadvertently enabled Rotary Mode, which uses a completely different Y axis setup:
If that’s on, turn it off and see if the situation improves.
If it’s not on, upload the offending lbrn2 file and pictures of the result so the hive mind can mull it over.
Ok thanks. I’ll give it a try later.
