I don’t understand what i’m doing wrong. I’ve made sure all lines are touching the other lines, and have attempted “Close Path”, and “Auto-Join selected shapes”, but I don’t think the auto-join selected shapes is correct for lines. but either way, I can’t get them all together.
ShapePathClose.lbrn2 (9.3 KB)
The basic gotcha: a “node” can join only two lines / curves, so a closed shape cannot have T intersections.
This has the outer path joined and the inner lines grouped as separate shapes:
ShapePathClose - cleaned.lbrn2 (10.0 KB)
That may not be quite what you want, but take a look to see what the differences are.
You can’t join those shapes as drawn. The shape needs to be a single continuous line without any extra parts to become a closed shape. I broke apart your curve shapes with node editor and joined the flat parts to the outer shape and had to change the curves to a different layer so you can see what happens.
I knew it was going to be something trivial. I sure did waste a lot of time trying to get those lines together lol. thanks for the help.
