Messed up my settings
Somehow I changed some settings. When I try to load a wasteboard or templete it loads as a 2x2" lower left screen. How do I change it so it will load as a 40x40 cm. Have looked everywhere and can’t find what I changed. You help would be most appreciated
Actually want it to be 400x400 it’s aleady 40x40
What are you loading the wasteboard or template from?
Can you take a screenshot of what you’re seeing?
From a download template file. Using a laptop and can’t get screenshot to work. Believe somehow I unlocked the axis and actually reduced the x/y axis but can not get it unlocked to reverse the change. Have re-installed Lightburn but image stays reduced, deleted the template and re-loaded but it still stays reduced. Just want to get it back to 400mm x 400mm
Open “Snipping Tool” program to take the screenshot.
Can you upload or link to the template file as well as taking a full screenshot of LightBurn with the file loaded please?
wasteboard file I am using is samcraft wasteboard
Can you take a full screenshot of LightBurn so everything is visible?
I had no idea what a Samcraft wasteboard was. After looking around it looks like something he’s selling.
Can you confirm that the file you’re loading is a .lbrn file?
yes it is a lbrn file
This is what it looks like on a pc not connected to the laser
Looks like you’ve defined your work area as something much larger than the 400x400 mm nominal I would expect for an Ortur Laser master 2 Pro. Have you enlarged your bed? If not, go to Edit->Device Settings and change the Working Size to the appropriate size. I assume 400x400 for your laser.
got it, probably changed it because I have a extension to put on but have not done it yet.Now all I have to do is learn how to use it
