Mi Sculpfun envía en la consola un mensaje de error:5 (My Sculpfun sends in the console an error message:5)
No puedo configurar la intensidad y el tiempo de impresión y corte porque manda un error
“error:5”
En verdad aprecio mucho su ayuda!!! No se exactamente cual fué el problema, pero estuve reconfigurando varias veces los parametros de impresion y finalmente ya funciono perfecto!!!
Estoy nuy contento con los resultados.
Muchas Gracias!!!
I cannot configure the intensity and the print and cut time because it sends an error
“error:5”
I really appreciate your help!!! I don’t know exactly what the problem was, but I was reconfiguring the printing parameters several times and finally it worked perfectly!
I am very happy with the results.
Thank you so much!!!
Can you describe exactly what it is you’re doing when you get this error? Also, please take a screenshot of the error that you’re getting.
Error 5 is just a warning, it does not affect the laser functionality. It just says that you send the homing command to it and it was not enabled.
Check here on how to set up your Sculpfun properly: Setting up the software - Diode Laser Wiki
