I am running Pro RC3, but it happened with all versions. When I try to use a hostname instead of the IP address, MillMage won’t connect. It works fine using the IP address. I can also connect with the hostname through the Web UI. I have tried two different PCs. I can also open a command prompt and ping the machine with the hostname without issue.
