Eleksmaker Pro A3…2.5 watt diode
GRBL 1.1e
MANA SR ver 3.1
Trying to get a better understanding of when to use min max power settings
is there a video or posting
For greyScale you can change both…for dither you can only change max
Thanks
This explains min / max for cutting; https://github.com/LightBurnSoftware/Documentation/blob/master/Operations.md#max-power
And this is min / max for engraving: https://github.com/LightBurnSoftware/Documentation/blob/master/EngravingImages.md#max-power
Since you have a GCode machine, you can only set the min power value when doing a grayscale engrave, to control the power that will be used for pure white.
