Min power and image adjust are locked and cannot be modified to engrave realistic photos new to this please help using light burn with atomstack A5 pro
Here you have the explanation.
Your project is an image so you can’t change mode.
If you change image mode to grayscale then you can use min. power.
so there is no way for me to use jarvis or stucki as a image mode
You can use others but not min. power. Greyscale engraves with variable power. The others use dot lengths to get an image.
Stucki mode
Greyscale
