Mind of its own
Hi everyone
As the title says I think my laser has a mind of its own.
I replaced the tube just over 6 months ago so out of warranty. I messaged the people I got the tube from and they got me to do a short video of the tube. They sent it to the suppliers of the tube and they think it’s got a leak on it due to the colour of the laser in the tube.
It was that bad it couldn’t cut through 6mm mdf oak veneer.
Today I thought I’d change my lens over to a longer focal length lens and it cut through perfectly. It even cut through 6mm+ natural oak perfectly.
I sent the head back to home and unfortunately the tip of the laser head hit the rail. I have checked that all is aligned correctly again and all seems good.
Sorry for the long story ha ha
So I’ve now gone back to cut the 6mm veneer and nothing. Not cutting through at all.
I did a ramp test to check again and there weren’t even any lines from the laser starting to cut even when I put a bit of masking tape under it. The laser was firing at the back.
I’ve then rest the laser did the ramp test again
and it started cutting but this time no matter where the head was in the ramp test it was still a thick line.
Does it matter how far the lens is from the first mirror? I’ve had the head tube pushed up and pulled down. I’m just at a loss as to what is going off with it.
I’ve attached some pictures of the cuts
If anyone has any clues I’d be grateful as I don’t want to buy a new tube.
Are we talking tube or head?
You have virtually noting on what makes you think it has a mind of it’s own. I’ve really never heard of a head being moved, as it’s uaually not easy to take them off and put them back on.
What size tube is in there and what kind of power/speed/lens are you using?
You can check it’s tem resonance using something like this link.
Good luck.
:grinning_cat:
I’d lay a few bucks the head tube is now misaligned enough to have the beam hit the inside of the nozzle.
Using either tape or paper targets, verify the beam enters Mirror 3 in the center of the aperture with the head at all corners of the platform:
Then verify the beam is hitting the middle of the lens:
Then verify the beam is centered in the nozzle aperture, either with tape or (if you’re as compulsive as some people say I am :grin:) the teeny target in the middle of that picture.
Adjust Mirror 3 to put the beam through the middle of the lens and nozzle.
With that done, you can verify the head is perpendicular to the platform.
The head on my OMTech 60 W machine has three screws (one on the far side) holding it to the bracket:
In turn, four more screws (one barely visible to the right of the head) hold the bracket to the X axis linear slide carrier.
Check the angle:
  • Focus the head as usual
  • Manual pulse to mark some cardboard
  • Lower the platform 10 mm
  • Another pulse will be defocused, but centered on the focused pulse
  • Ditto at 20 mm
  • Ditto at 30 mm (likely with a longer pulse / more power)
If the pulses aren’t concentric, then the head isn’t perpendicular to the platform or the platform has that much wobbulation as it moves. Adjust as needed.
That will almost certainly affect the beam alignment going into Mirror 3, so start at the top and check everything all over again. There is a major reward for being compulsive at this sort of thing, because the optics are utterly unsympathetic to misalignments you’d think should not matter in the least. :grimacing:
Also, the machine settings should not permit the laser head to hit anything. Because it crashed, you should verify:
  • Home switch position & stability
  • Actual (not nominal) X and Y maximum travel distances
In short: if you can manually jog the head into a collision, then something is wrong with the settings. Jog carefully and fix whatever lets you crash it.
I don’t know if the tube or the head is an issue. What makes you think the tube moved? He switches from talking about a tube he replaced 6 months ago and how the new one is bad. Did he upgrade to a new tube?
Then he’s talking about moving the head to different machines… so at this point, I’m at a loss to understand the entire issue.
Don’t know if that’s what he did (replace tube) then hit the head somehow… and then you added the tube being an issue…
You’re right he shouldn’t be able to drive it out of bounds, the controller should catch that.
We’ll have to wait until he responds and clarifies what’s happening. One of the reasons I replaced mine, most of these heads have little to no adjustment. At least on mine it’s easy to adjust and stays put. It’s pretty close when I replace a tube.
If you look at my original head.
I think it’s pretty clear, it wasn’t right for me to target the center of the hole, which puts the beam offset from the lens. With an 8 to 10mm beam it’s could be clipping the head. A 20mm mirror is only ~14 mm in that one direction, that only leaves 2mm/side for a perfectly centered beam. :thinking:
Just a comment…
:grinning_cat:
the tube is a 60w spt-laser-tube-c70. I use 8 or 10 speed and 70 power. the lens is either 50.8mm 20mm or63.5mm
i had this before when i changed my controller. the head wouldn’t stop and kept running into the side.
When ive aligned the 3rd mirror downwards ive tested it at the nozzle tip or taken the tube in the laser head out and tested the both ways. if i do it with the lens tube out then put it back in it will hit the tip.
I use the targets on the first 3 mirrors and have a bit of wood with a hole in which fits my nozzle. this method shows that the laser is central when pulsing.
With the head this time i had the tube in the head lower so when it went to the home part. I was wondering if having the tube in the head with the lens in it higher or lower would make a difference. obviously the focal point is tip to table.
Sorry i meant the tube in the head with the lens
I haven’t said about moving the head to different machines. Not sure what you mean
So what i was trying to say above is the head homes to the yellow where the rail is. It will sit just above the the corner where i have circled it in yellow (closest to the bed). When i replaced the lens the tube was just a smidge lower and caught on that rail. in the picture the lens tube is pushed right up.
Because the collision was in the corner with the home switches and they’re not easily relocated, I’m reasonably sure the nozzle’s position must be high enough to clear the surroundings.
If the tube is similar to the one in my laser, the focus lens is just above the clamp for the red-dot pointer and in a fixed position relative to all the gimcrackery hanging off the X axis bearing follower. In that case, the (vertical) position of the nozzle doesn’t matter, because the focus point is always the same distance below the lens.
The nozzle is (probably) adjustable so you can position it closer to the material after focusing to encourage the assist air to blow through the kerf. If that puts the nozzle where it can hit the side(s) and you really want it that low, then you must relocate the home switch(es) accordingly.
I’d put the nozzle at a safe height and just not ever move it again. :grin:
With it hitting the corner was my fault. My bed moves up and down for the focus. I just wasn’t sure how much the lens tube has to protrude out. The Home switches do work. It’s just me not putting the head up enough to clear it.
I’ll have to go through the alignment again (constantly having to do it recently) and make sure it’s all perfect again.
With the small wooden alignment part you made does that sit on the tip of the nozzle or in the head when the lens tube is out?
All those targets come from manila file folders or similar heavy paper, so there’s no wood involved.
The 3 targets go over the Mirror 3 entrance aperture to verify the incoming beam from Mirror 2 across the platform.
The F targets sit where the focus lens would be; I take it out while fooling around to avoid embarassing accidents.
The tiny target gets taped over the nozzle; most folks just squeeze the tape there. In either case, it’s on the outside to show where the beam emerges relative to the orifice. If it’s not centered, then adjusting M3 to fine-tune the already-centered beam at the lens should help.
As with exercise, you don’t need fancy targets. All you need is motivation. Hang around here long enough and we will give you motivation. :grin:
