Minimise function missing from the top bar
Since the latest software upgrade I am unable to minimise the light burn page or window and work on other open windows? I have a laptop Latitude E7250 with windows 11 .
I am not sure how to submit or raise a ticket with Lightburn themselves ?
The Suggestions does not tell you how to use this page either ? I am not sure how to start a thread , How to comment on them or anything by luck I got to this function to create a new topic not sure if this is the correct way ?
If I am reading this I believe you got this!
Try to press Windows Key + up arrow. This shortcut solved some issues similar to yours.
Maybe @soniclab can provide some more help.
Looks like the minimize button might have gone missing after the update. A quick workaround is to press Alt + Space while LightBurn is open, then choose Minimize from the menu. You can also right-click the LightBurn icon in your taskbar and do the same thing. If it’s running in full screen, pressing F11 or dragging the edges of the window can sometimes bring the buttons back. If none of that works, you can reach the LightBurn team directly through their support page here: https://lightburnsoftware.com/pages/contact-us.
The latest versions of Lightburn seem to work best in the full screen mode. I, and others, had to use the disappearing Task bar to see the bottom stuff. I just have it pop up when I need to access another program that is already open.
