My Mira 9 100 watt is no longer cutting. I did all the calibrations and mirror alignment and still nothing.
The machine is about 5 years old. No warning came on or anything that I would of known of.
I did notice every time it was cutting you would hear some sort of a clicking sound. Would this be a sign the tube needs replacement? I do change the water every 5 to 6 months and use distilled water. Any help is appreciated.
Could indicate electrical/insulation failure of the tube and should be clarified. The power supply itself should also be checked (if it was my machine).
If it has been going on for a long time, it is quite possible that the tube is gone.
Is nothing coming out of the tube anymore on M1?
I can’t imagine environments that would require changing every six months.
Unless the tube and water hoses are exposed to a lot of UV light and the water system is not leaking, there should be a much longer time interval between water changes.
How do you check your lps? There seems to be a strange area of performance from the lps → tube and I don’t know how to check lps alone.
I know about the load it down with a relatively small value resistor that’s rated at 40W, but that really doesn’t tell you much.
My experience with dc excited tubes (glass tubes), is if it arcs, then it’s already punched a hole in the insulation, leaving you kind of sol. That area needs to be replaced.
Any advise you can share on testing of an lps, I would be grateful.
I do not want and cannot measure whether the lps meets the given tolerances, but if I have a tube that is fully functional, but does not work as it should with this tube, it will be discarded.
Isn’t it “good practice” to replace the supply, together with the tube, if it retires? You have the better experience here with your 3 or more tubes you have replaced in the last 5 years - if I remember/count correctly
The tube from my first CO2 laser, which I repaired and later replaced anyway, was mechanically broken, my “60” Watt machine still runs fine with its no. 1 tube. When it needs to be replaced, it is replaced in a set, with the power supply for the tube.
Unfortunately, when they fail, you don’t know if it’s the tube or the lps, without swapping one of them out. When mine went out of TEM00 mode, could have been either, but more likely the tube, it was.
Yes, I’m on tube number 3, same lps over about 6 years. I do believe a major part of the issue is the normal day heat, which can be in the 110F+ range, has to be bad on the gas mixture… just speculating.
I babied my first one, it failed in about two years, I abused the next tube, both lasted about 2 years. ![]()
The reasoning for me is relatively simple. I’m lucky to have enough funds to buy the tube, I can’t justify going in the hole further for an lps that I think is working but have no way to really test it.
That’s what I get for being broke. ![]()
The Mira 9s (and most likely the rest of the Mira series, but I can’t speak for the newer models) lps has an output screen that displays either the mA being used or an error code. Or, another form of error, the screen being off.
Worth checking out if there’s an issue. For the Mira 9, it’s a black box under the left side cover panel.
