I and new to engraving I purchased a neje master 2. I had to follow the programming instructions to get it working on lightburn. As of now it’s mirror burning and when I move it around manually it seems to move properly. As it when I move the up arrow the it moves away from em and when I move it left it goes left. Any ideas?
Go to Edit > Device Settings, and in the upper left of that window is an ‘Origin’ control with 4 dots. If the engraving is mirrored from left to right, move the corner from left to right or vice versa. If the engraving is upside down, move the dot from top to bottom or vice versa.
When you get it right, what’s on screen should match what comes out on the laser.
I will give it a try thanks
