send project to the 80W OMT laser on lightburn the image is left to right but cuts right to left. Words on the project are also mirror image
If you go to “Device Settings” in the upper left is a setting called “Origin” with 4 dots, one for each corner. Pick the corner opposite the current one in the direction things are mirrored.
So, for example, if your output is mirrored vertically, and your origin is currently on the bottom, move it to the top.
