Mirroring of the transmitted image
Hello groupers. I’ve been working with lightburn for over a year now and today I have a problem that I can’t solve. The situation forced me to install the program and reinstall it. After restarting the laser, it turned out that the burnt image is a mirror image of what is on the preview. Maybe someone from the group had this problem and knows how to solve it. I would be very grateful for your help.
thank you very much for your suggestions, it helped, I didn’t understand what the “origin” was about right away, but it worked and everything is ok. Thanks again. Greetings from Poland Waldemar
This may be due to an incorrect Origin setting in Edit->Device Settings.
If your profile is up-to-date you have Atomstack and Sculpfun lasers. In this case Origin should be set to bottom-left dot.
