Question when i use the flood fill scanning im getting missed areas so how can i corrected this?
Most likely the right part of the Y was done from bottom to top, and the left part was done from top to bottom. If you have backlash on your Y axis (mechanical slip when you change direction) it would cause this. The fix is not to use Flood-Fill so scanning happens all in the same Y direction, or fix the backlash on the Y axis.
I will check that out, i will run a test i have 3 other lasers set up i have only used flood fill on the one machine.
