Missing icons on the left
There use to be icons on the left side after the ruler icon, the offset shapes icon, the Boolean icons , a corner trim that change corners into arcs, etc.
How do I put them back?, since some how I misplaced them .
Thank
Under the windows tab. Modifiers checked?
From the menu, click ‘Window’, followed by ‘Restore to Default Layout’. Much of the UI can be moved and arranged in different layouts to provide flexibility and to best match your workflow. You may have turned off or moved those inadvertently. :slight_smile:
Thanks, this was the solution, thanks
