I just switched from an old Windows laptop to a MacBook Pro. So far everything looks familiar except for 2 things. I can’t find the “Fire” button I used to use to set the current position on my workpiece. And I can’t find the little box for setting the power level for use in previewing the location of the laser (Fire) or when using the frame command to show the outer boundaries of the current job. Other than that everything looks much the same.
I just did a fresh install yesterday so I presume I have the current version. 1.7.06
Is there a place where those interface items are toggled on/off?
Instead, migrate all your old settings to the new machine:
It’ll make the laser work the same way, too!
How do I do that?
Click the link he provided.
Ahem, yes, sorry. After I sent my message I noticed the link and followed the instructions and brought over my old settings. The 'Fire" button and. the fire power setting box came back. Looks like I’m good to go. THANK YOU!!
After this set up was working fine for a while I later had some sort of glitch and the “Fire” button plus the & power box disappeared. I could not create a new instance of the laser that showed the Fire button so I had to reload the setup I had saved to the USB stick. But this concerns me that the setup could be so fragile.
