Missing lines on 2 of the 3 pieces
I have reviewed the posts here for missing lines one is unanswered but all else are good. The bow seemed to relate closest to my issue. I have set up 3 glasses in a template. I have set up 3 identical crests to etch on the 3 glasses but on 2 of the glasses the line to the right of the eagle is missing see the images.
Here is how 2 of the glasses came out the third had the line
I hope the image is clear enough to see I can take different pics if needed and share the job as needed… I find it strange that it is in the middle of the image and only on 2 of the 3 glasses …
Post the lightburn file. My guess is that when you selected the left image to copy to the middle and right images, that section of line did not get selected. Such little gremlin problems haunt my laser, too.
Did you select the whole left image and GROUP the items into one object? Then copy the left image into the middle and right slots?
Yes, I modified the left one and did a ctrl-D 2x for the other 2 copies. The file is below … what I will try today is that I have used the offset tool (in the enclosed copy) to create a 2nd line on all 3 of the copies individually
This is the template to use for Scotch Glasses.lbrn2 (366.4 KB)
I looked at the file you posted, and cannot find any way to miss that line segment. I see no errors in the file.
Sorry to not be more helpful.
Have you tried to run the burn on scrap wood to double check how it comes out on a flat piece?
I am in the shop now about to try the mods I made today … will update after that run
I have now done 12 glasses and all of them are perfect. Thanks all for taking a look
