Hi, everyone. I have a general problem and I think that this is due to the software, maybe especially the conversion to the metric system…
To show the problem i have done the follow steps
TAB “Laser” → go to “Home”
TAB “Move” → Get Position
Return value = x=0.00, y=0.00
On the workspace, the position point is also at 0/0
TAB “Move” → go to x=0.00 and y=200.00
But the laser only movesabout position y 110mm.
On the workspace, however, the position point is now exactly 0/200.
TAB “Move” → get position
Return value = x=5.00, y=11.89
On the workspace, the position point also goes to the read position (x=5.00 y= 11.89)
I use mm as the unit.
There seems to be a problem here, or are there other settings that affect this?
Kind regards
Ralph
Thanks for the answer, but that’s not a problem with the step size (steps per mm). If I draw a rectangle with an edge length of z. b. 100mm x 100mm draw and output is exactly right.
Great. Thank you for your great support. Now the positioning works as expected. However, I don’t know where the wrong zero point ([G54:5,000,-88,113,0,000]) came from.
