Hello everyone,
I need some help troubleshooting a connection problem between my laser engraver and LightBurn.
My machine has:
Controller: MKS DLC32
Firmware: GRBL 1.1h
Laser: 5.5W diode laser
Work area: X 301 mm × Y 300 mm
Connection: USB
COM port: COM4
Baud rate: 115200
Steps/mm: X 80 / Y 80
No limit switches / endstops
The important thing is that the machine communicates normally with LaserGRBL using COM4 at 115200 baud. I can connect to the controller and use the machine normally in LaserGRBL.
However, when I try to use LightBurn, it does not establish the connection. LightBurn remains at:
“Waiting for connection…”
I have already tried disconnecting and reconnecting the USB cable and restarting the software.
I would like to know if there is a specific device configuration that should be used for the MKS DLC32 in LightBurn, or if there are any settings such as baud rate, DTR, connection mode, or GRBL device settings that I should check.
I am currently using LightBurn 2.1.04.
Could someone please help me determine what is preventing LightBurn from communicating with my MKS DLC32?
Since LaserGRBL works correctly with the same controller and USB connection, I believe the problem may be related to the LightBurn device configuration or connection settings.
Thank you for your help!
