I’m a long-time user of LB and starting CNC currently with Aspire and GSender. My main concern was with gsender as I would like to have more controls on running my cnc. So, I DL MM trial to see if it is worth shifting. So, for the design it’s copy of LB, no problem, but:
I found that the toolpath icons are not really helping to understand what they are (to say the least)
It’s not possible to see the duration of one operation without running a preview (or I didn’t found where it is… )
It’s not possible to locate the spindle on a precise location of the drawing to check where specific parts will be engraved (link with wood defects or particularitie s)
the “move” commands are very basic, much better in gsender (free softwa re)
I hate to have to tick a box to change from one jump to continuous move. On gsender one click is one jump and a continuous press, triggers continuous move, so you can approach your target with continuous press then fine tune with some cli cks.
Always on the “move” you don’t have pre-selected button (precise, normal and rapid), you have to choose from a drop-down list, which is lo nger.
To sum up I think that MM is very good price/quality for the design part, but less good than aspire (of course not the same price). The main issue for me is the command of the CNC. MM has to improve a lot this area compares with free sof tware.
Hope these points will give some food for thought to the developmen t team.
you can use view paths under operation tab or control mode under job tab ,just toggle of the operations you dont want to see
unlike LB there is no pin tool which i do miss and it originally was in MM but was removed for safety reasons
theer is a couple of ways to move spindle manually to get a precise view of were material will be cut engraved , hover mouse on point of job you want spindle , check XY cords bottom left of screen
jump into goto type cords and hit goto , other way is just use jog arrows and check position on screen , id do this on my 3m X 1.2m table with no worries , or i just use a bluetooth key board if i want stand at table and jog spindle that look back at my screen to see wheer it is on dessign
comments on forum from previous gender users change once they get used to MM they like MM set up
more control like what , how long have you auctually been using MM?
You did not mention which controller board you are using, so it may be an issue that your board is not fully supported yet.
At the top of the page is the Feature Suggestions menu. Submit your ideas so the Forum members can vote on them.
There are seasoned CNC mill users that have switched to MillMage from Vectric and Aspire. It is hard to switch when you are used to something, but they thought it was worth it.
