I’m trying to setup my first rotary burn and in the set up it asks for mm per rotation. I don’t understand this because for the last 30+ years of 4th axis work, it’s always been in degrees. I’m confused why lightburn needs this info since I’ve already given it a diameter. The mm per rotation will change with every new diameter on every workpiece but the number doesn’t change when I enter a new diameter.
Lets assume my workpiece is 1"…now lightburn knows that the circumference is pi…so do I just enter 79.7963 mm per rev??? Why doesn’t lightburn automatically know this when I enter the diameter?
Additionally, why does it need this? I’ve given it a diameter and it knows the size of the picture that will be “wrapped” around that diameter. I don’t even know if I’m asking the right questions.
I should mention that I’m using a 100mm chuck and cnc router is not connected to lightburn so I can’t use the “test” button. I don’t even know what it would be testing for.
Edit…hold the phone! I just realized that I had not selected the A axis…derp.
