Mode fill and lin
i watch movies on youtube about lightburn and i see there the options fill and line ,line .fill and offset fill
but in i cant find the mode fill and line anywhere in my lightburn options
someone set open the layer and hit the + but then i get a extra layer but not the extra mode option
Those videos were probably done with older versions of LB. You now set the main layer to ‘Fill’ then add a sublayer that you set to ‘Line’. Something like this:
This is also dependent on what type of design files you have loaded in LightBurn. Fill and Line will only show up when you have vector lines in the layer you are modifying. If you have an Image file (jpg, png, etc) loaded, you will not show options for Fill and Line. I’d highly recommend you spend some time going through this section of the documentation:
