Hi everyone,
I need help getting my Monport GT30 MOPA fiber laser to work with LightBurn Pro (Galvo license).
System & Setup:
Machine: Monport GT30 MOPA (30W Fiber Laser with BSL controller)
OS Tested: macOS (primary) and Windows
LightBurn Version: Latest version with active Pro/Galvo license
Device Setup: Imported the
.lbdevconfiguration file for my unit.
The Issue:
The machine only works on Windows using the native BSLAppSimple software.
It does NOT respond to LightBurn on either macOS or Windows.
In LightBurn, the status at the bottom right displays “Ready”, but the machine gives zero response:
Clicking Frame does not trigger the red guide light.
Clicking Start does not fire the laser or move the galvo head.
What I have tested so far:
On macOS: Granted Full Disk Access permissions in System Settings and tested direct USB connections.
On Windows: Swapped drivers via Zadig (tried both WinUSB and libusb-win32), closed all BSLApp background processes via Task Manager, and re-created the device profile manually as JCZ/BSL Galvo.
Hardware Checks: Verified physical safety controls (E-stop disengaged, key switch ON, Laser Power ON, Z-axis set).
Layer Settings: Ensured speed, power, and frequency values are correctly set (e.g., 1000 mm/s, 30% power, 30 kHz).
Since the hardware works completely fine with BSLAppSimple under Windows, the machine itself is functional. However, LightBurn fails to communicate or send commands to the BSL board on both OS platforms.
Has anyone with a Monport GT MOPA / BSL board successfully resolved this handshake issue with LightBurn? Any guidance on drivers, board settings, or macOS setup would be greatly appreciated.
Thanks in advance!
