I have just got a Monport Pro 30w Fire - I have diligently followed the instructions on setting up Lightburn for the Monport, including using the EZCad Config file.
But after all of that I cannot get the machine to be seen by LB.
I have checked my ports. In system information the laser is seen under one of the USB3.1 ports as ‘SEA-LASER’
I have tried different cable, restarting the laser and Mac in various combinations…
I even tried another Mac but to no avail.
Any clues would be super helpful. I am at my wits end trying to get the two to connect.
I don’t have a fiber so not sure about setup. If it’s seen by the OS, it should connect. Have you followed these docs including importing the markcfg7 file?
It is showing up in system, under whichever USB port it is plugged in to. I tried them all thinking it might need to be a specific one.
Also followed those instructions and used the markcfg7 file. That all went smooth, but on the main Lightburn screen with the device selected it just says ‘disconnected’ and ‘waiting for connection’ at the bottom.
I did also try a dumb hub and various other cables and a-c converters.
I was wondering if it might be a machine issue. It is fresh out of the box so I would really hope not but I just can’t imagine a reason it can’t be ‘seen’
Thanks for all of your help! In the end Monport were quite helpful and forwarded some further documentation. You are right the laser was indeed not to be set up as JCZFiber as per original instructions.
After setting up as BSLFiber we got connection and everything is now working smoothly!
Hopefully this thread will prove useful to others in the future,
Thanks again for the super helpful replies
