I just got the Monport Onyx-R and have run a few files successfully. However, I wanted to engrave and cut some 1/8-thick acrylic. I tried to run the lettering, and nothing happened. It revs up, but there is no movement. So, I tried to cut a layer with “cut selective graphics” toggled on, and it worked fine.
I have a custom computer running Windows 10, using Lightburn 1.7.01, DSP.
This is what I have tried so far.
I thought it might be a transfer error and read that you can reset the connection by right-clicking the “Devices” button, but nothing happens when I right-click “Devices”. When I right-clicked on the COM selection, it asked if I wanted to exclude the COM port, so I did. That didn’t work and now I can’t get the COM port back, I am supposed to be able to right-click on the COM selection and include the COM port again, but there is no option to include that COM or any other COM.
I have not tried to completely uninstall Lightburn, only because I have 2 other lasers that I don’t want to screw up as well.
I have tried different USB ports, removing the laser from Lightburn and adding it again, and swapping out cables that I know work, but still no change.
Here is a screenshot of the COM it wants to connect to:
Here are screenshots of my settings.
