More tutorials please for building complex shapes?
I am working on o scale designing my buildings. They are going to be European and I am just seeing what I can come up with. If you see the building on the right, I like where I am going, but I need to make the “crown " symmetrical” . I used the combine tools at get my outline looking the way I wanted it, but I am not sure how to draw curves yet. I can design this in another window and just import it and attach it to the perimeter of the building so it burns as one face. I also want to give the other buildings crowns. Are there videos on this site or can you direct me to other videos on Youtube to watch that are more in depth. I see to be having trouble getting arches to work.
Cafe Front wall.lbrn2 (45.1 KB)
I am not sure either but I to work it out I would do the following:
Using “create elipse” tool trace an elipse with the curve you need. Then using “create rectangle” tool draw a rectangle over the line you need. Select both shapes and use “Cut Shapes” feature on the tools Menu.
You will get to shapes, one is the curve you need the other is what’s left.
This is not for what you need but maybe can help.
