Mouse gets stuck in pan mode 9/10 times I run the program
Hello. I’m having some troubles getting the light burn program to work reliably on my machine. There is rarely a time I open the program without this issue. I will be attempting to grab and drag an item from one part of the build space to another, and my cursor gets stuck in pan mode. When this happens, trying to move an item will result in the workspace freezing. Upon releasing the mouse, the view will suddenly shift in accordance to how I move the mouse as well as moving the selected object. I am unable to select objects and drag them without this happening after only a few minutes of having the program open. Is there any documentation on how to fix this? I only saw an old closed thread that said not many people had this problem. Running one version behind the latest on my linux based laptop. The only thing that is able to resolve this issue currently is to either select the pan tool, drag it around in the build space, and re-select the cursor on the left hand hot bar, or restart the program.
Another issue I haven’t been able to resolve is scaling. The settings don’t seem to adequately be able to scale the UI elements up large enough to see without squinting, specifically the cursor when hovering over graphics or lines.
Any input on resolving these issues is appreciated, thanks for your time and help!
Try with a different mouse. Sounds like a possible hardware issue.
As for scaling. Can you take a screenshot of what you’re trying to address?
