Move Laser to Home after Framing
Is there a way to make the Laser move to the Home Position after Framing? I am using the Absolute Coords and when I frame a file the Laser stops in position. I would like for it to go to the Home Position when finished.
Depends on the controller you have. In the Menu (on controller not in LB), User settings there should be a “Return” position. change this to Home. Try That
I’m using Ortur Laser Master 2 Pro SF, so I would need to do it in Lightburn.
I’m not aware of any way to do this.
As a workaround, you could create a separate layer that contains an object that encircles your design. Set that layer to frame level power levels and speed. Then run a job with just that layer. The laser head will then return to its original position.
A little more work but might be useful if this behavior is essential for your workflow.
