Hello, I am pretty well versed in LB now, but for the life of me, I can’t figure out how to move the laser to the outer most corners for positioning. Kind of like framing, but I would like for it to stop in the corners. Can someone shed some light on that for me?
I use Origin and place my curser on the outer edges and in the middle to check locations.
Will activating the Set Laser Position tool and clicking in each corner suffice?
It shuts itself off after a while, so if you’re doing complex fiddling in the corners, you may need to turn it back on for the next corner.
Select the shapes, then Arrange > Move Laser to Selection > and pick the corner / side you want.
