"Move" window all grayed out
As you can see from the image, my “move” window is all grayed out and I cannot set up the origin point. Without this, I can’t start cutting.
You can’t move a galvo machines position… at least not in the way I think you’re thinking.
:grinning_cat:
As Jack mentioned, you don’t need the Move window to position a Galvo machine as you might be used to when you’ve worked with gantry-based lasers.
Galvo Fiber lasers always work in “Relative Coordinates” and you can use the framing feature to project the design on the workarea for an accurate placement.
If it’s still not possible to run a job, please give us some more background information. Which laser are you using? Did you add your machine according to these docs?
