Hi, I’m considering buying this awesome SW but ran to an issue with laser not lighting up when tryiing to cut/engrave. The machine moves like it should but without lasing. When I save the gcode and run it in LaserGRBL it behaves the same. GRBL should be set correctly, $32 is enabled. Any ideas?
Check $30 max power setting it needs to match lightbulb setting either 1000 or 255.
