I purchased longer Y rails for my Burnlab laser. I changed the bed size in Edit-device setting to the correct bed size. My issue is the new rails measuring ticks are further up on the rail. So the 0 y axis starts about 30mm before the 0 on the measuring marks.
Essentially I need to have the laser cut area move up that 30mm. If that makes sense. I have watched so many videos and nothing touches on that.
No, that doesn’t really make sense Do NOT rely on the ticks marked on the rails. Maybe put some tape on the ruler to not disturb yourself. You should mark the 0,0 position either on the honeycomb bed or the waste board. Put some guide blocks on the waste board such that you can align objects at 0,0. Use the origin of the laser, don’t care about the frame.
