Hi all, I have just installed Lightburn for my Mr Carve S4. I designed a few thins but whenever I try to engrave the objects designed are beggar than the original. It is odd, cos when I use bslsimple software the size is true to size, with Lightburn the size is bigger when engraving. for example a rectangle 17mmx11,5mm becomes something like 22mm x 15.5mm, How can I fix this?
Thank you for your help
Simon
