Hi,
The solution that is given for the problem that user Wabcriel asked for doesn’t work like it should.
When i put the defaultprefs.ini in the lightburn install folder (c:\program files\lightburn) the override does not work.
It only works when i copy it to c:\users"username"\appdata\local\lightburn. This doesn’t work in a multiuser school environment.
I hope it is possible to fix/change.
Best regards, Daniel
