Hi everyone, I am using a Snapmaker A350 2.0 20 Watt laser. I am on Lightburn version 1.7.04. My issues, is that when I try to cut out multiple objects on the same layer, it only cuts the first object. Attached you will see 2 objects, 3 layers, the text layer writes the text out on both objects, the image layer engraves both images, but when it comes to cutting them out, the 3rd layer, only the first one cuts, for the second, the laser runs around it, but doesn’t come on.
What happens if you create another layer with the same settings as your blue layer… assign the outside shape to the second line layer?
