So I have two lasers, so per suggestions from Oz, I have multiple instances of Lightburn running on my Windows machine. What I am trying to figure out is if I can force specific instances to point to specific lasers on start-up. So if I double-click on one shortcut it will always try to connect to the Ortur automatically, and if I click on another it will always try to connect to the Neje. Any help with that would be appreciated. Thanks!
Sorry, but this isn’t possible at this time. LightBurn stores all preferences in a single file, so the last instance you close will be the remembered settings.
Okay, thanks for letting me know. Perhaps when you’re ready to implement it, a switch used at the command-line when launching the application that could be added to the shortcut that could designate the laser profile by name (whatever you named it when setting it up)? Just a thought. Thanks again.
