Multiple passes on a circle do not line up
I have been trying to make multiple passes to cut through the material however my circles do not line up.
What do you get if you make a rectangle?
I had to go test it but rectangles line up perfectly.
If you look at the circles theyre tighter exactly.180 degrees across and fatter on the other sides. I think you may have a belt slipping or a coupling set screw loose and slipping the rod. When you do simple rectangle it only moves one axis at a time. Circles are constant combination of XY so they need to be quite synchronized.
