My absolute coordinates are enabled, it frames the template but when it burns the image it is off centre
Your result indicates a mechanical issue.
This test pattern is useful to identify mechanical problems:
Backlash.lbrn2
Scale it uniformly to fill the platform and run it as fast as the machine will go in Line layer mode with Enable optimizations turned Off and power set to mark a sheet of cardboard. Any differences from the design will be informative; a crisp photo will let us look over your shoulder.
Also, please use screenshots instead of cellphone pix.
This is a useful test because it can show whether the problem is mechanical rather than just a LightBurn setting. Running the pattern fast should make any looseness, belt slack, or backlash easier to spot. A clear photo of the finished test would make the results much easier to compare.
Here is one provided by Lightburn recently that is supposed to be an updated version.
BacklashCheck.lbrn2 (136.1 KB)
