Nortons method for etching white ceramic Tile or Glass or Cups or Plates(for Diode Laser)
NICKY NORTONĀ·FRIDAY, MARCH 6, 2020Ā·
AIR ASSISTā¦ will reduce āBlacksā (but on some Co2 Lasers you will need air assist to keep lens clean)
DO NOT USE GREYSCALE
1ā¦Prepare Photo with a photo Editorā¦(LightBurn now has photo prep under shape properties)
2ā¦set size of photo to size you will laser on tile
3ā¦set DPI to around 300 (this really depends on the size of your Laser Beam)
4ā¦clean white tile with Lacquer thinner
5ā¦paint tile / Glass Flat Whiteā¦allow to dry (one light coating should do)
6ā¦fine focus Laser beam
7ā¦pick Image Mode to use ( I prefer Jarvis Dither and have had some success with Stucki Ditherā¦Available with LightBurn softwareā¦this preference takes some trial runs and documentation ā¦if preDithered use LightBurn āPassthroughā
8ā¦for my 2.5 watt diodeā¦speed 1200 mm/minā¦power 85% (my S-value in LightBurn =255) Line Interval = 0.085
9 takes approximately 50-70 minutes to complete
10ā¦clean off all paint with Lacquer Thinnerā¦
11ā¦place felt pads on bottom to prevent scratching
Video
How to Focus Diode
Prepping Photos to Laser
Basic Steps
Dithering is done when converting to 1-bit black and white from either greyscale (8 bit black and white) or color. Dithering is one of the last steps. Hereās a typical flow
- usually resize for your DPI and finished engraving dimensions. DPI is based on your beam size and burn radius (upgraded optics usually as small as 0.08mm, stock optics more like 0.10mm) anything more you will be overlapping lines and quality will actually get worse
- convert from color to greyscale
- Unsharp mask (to give it pop)
- Adjust tonal curve (because mid-tones do not process well in engravings
- Brightness/Contrast
- Convert to 1 bit (dither)
- Process in Lightburn as passthrough
These are the basic steps, and each photo is different, you need to develop the laser āeyeā and know what looks good when finished. It takes time and practice. Some photos just wonāt engrave well, due to limited quality.
44
1 Comment
Like
CommentShareSave
Comments
