My laser engraving speed wont go under 50 mm/s
So, I have a OMTech 50W CO2 Laser engraver, and the engraver will go as fast as I type in to lightburn like 200mm/s, but as soon as I go under 50mm/s it goes the same speed and finishes at around 2 minutes and 30 seconds. It is only on images that I try and engrave, if I just draw a square in lightburn with the square tool it will do all speeds fine, but as soon as its an image file it does not seem to want to do speeds under 50 mm/s. I’m not messing with the jogging position at all on the controller itself either, I’m solely trying to change the speed on lightburns software. Any assistance would be very helpful, thank you.
