My laser has a big problems!
How can I reset the Lightburn from scratch, to its initial settings.
And I also have the problem with my neje laser that is not aligned and is not cutting perpendicular.
I need urgent help please
This is a common request. The settings are robust to prevent accidental deletion.
It is almost always best to determine what’s going on and correct the settings.
Please avoid resetting to initial settings. It almost always increases the time it takes to resolve unanticipated behavior. Initial settings usually require further adjustment.
Does the work engrave in the wrong location?
Is the line shaped correctly?
Please use windows Snip to capture the screen so we can see what you’re seeing on the monitor.
You can also post pictures of the behavior you’re seeing so we can get an idea what’s happening.
