My laser is overshooting my cup on the rotary
I am having issues engraving a new design on a yeti. I have engraved thousands of cups with no issue, and now all of a sudden, the laser is overshooting the cup. For the width measurement, it is 287 mm, but the laser is overshooting on both the framing and engraving by at least 200mm and starting half way done the cup. User origin is set…I have spent over 3 hours on the phone with support from Aeon, and when I e-mailed them the design, they are having no issues with the measurements. I have tried this design on both of my Aeon Lasers and two different piburn rotaries with the same exact issue. The only thing that I can think of is that it has to be a software issue. Please help! Thank you.
Hello Shirley and welcome to the forum.
Set Start From to Current Position and read the following doc:
They have been doing this for ‘thousands of mugs’, I think they likely have the coordinate system down if they’re configured with a user origin.
Sometimes is frustrating to me to read others start out with changing how they laid things out, I’m talking about the coordinate system. Especially when I do user origin almost exclusively with everything except jigs.
I think their history shows we should look elsewhere, along with the fact they’ve been on the phone with Aeon for hours.
What kind of speeds are you attempting? Are you set for mm or inches?
Also what does ‘all of a sudden’ really mean, middle of job, next day or? What did you change between working and not working?
We’re all here trying to help, so give us more information such as the .lbrn2 file, if possible. And @parsec may be correct anyway if our facts are incorrect.
:grinning_cat:
Thank you Jack. I feel as though this is a software issue if it is happening on both my Supernova and my Mira 9. I went on business trip, and when I came back I had to complete some orders. I placed the yeti on the piburn as always. I have made no changes at all in the software, including not doing the update. Set my origin like normal. Settings are for engraving: 450/55/50; with a line interval of 0.07. I use mm. As soon as I send it to the laser for engraving, the origin is starting about half way (laser is engraving) down the yeti and because of this, the entire image is overshooting the bottom of the yeti. I have double and triple checked that the origin was set, rotary settings are correct with respect to the measurements. I have unplugged both lasers and rotaries and restarted with no changes. Even when I frame the design, it is overshooting. If Aeon support can frame out my design with no issues, I have to think it is something within the software…I am using the same license on both of the lasers. Any help is greatly appreciated!
Very unlikely that both machines have the same hardware failure. Can you post the actual Lightburn .lbrn2 file for us to examine? I understand if it’s proprietary, but it would appear to be something that changed in the software.
If you went away and came back with absolutely no changes, then I’d suspect hardware since all the software is set the same. However if you put this on another laser and get the same results it returns us back to the software or it’s configuration.
I’m afraid we need your source file (.lbrn2) to ensure there isn’t anything you’ve overlooked. I can’t see it being hardware.
Believe me it happens to all of us. Something you’ve looked at 100 times and just don’t see it?
:grinning_cat:
Just thinking out of the box. Is this a file you’ve used before? I’m wondering if there is a small out of bounds vector it’s calculating in the burn. I’ve had this happen by accidently making small squares or circles when moving the project around.
If it is proprietary, Message it to @jkwilborn instead of posting it.
If it’s proprietary, then it’s best to go through Lightburn support. I don’t want to be responsible for this type of stuff.. Thanks anyway…
:grinning_cat:
