My laser no longer has output
I just changed my laser from 175175 to 110110, had to correct the scaling but that is not an issue, had to adjust the offset of the red laser but still not an issue, what is an issue is the the red laser is not scaling to the same size as the cut image. How do I address this?
Do you have multi color laser?
You need to clarify what the problem is more concisely.
What are you doing and what do you expect.
You can leave out what isn’t a problem… :slight_smile:
