My laser stays on while moving between shapes
I NEED HELP !
i am trying to burn one of my first projects and they are not turning out. As soon as the job starts (being ran through g sender 1.4.11) the laser turns on leaving lines all over the wood. once the final line is made and my longmill is returning to zero the laser shuts off . I believe I followed to correct setup by scienci labs to change my S max value to 255 and minimum spindle speed to 0.
  1. Is your Device type GRBL, with no additional letters behind it?
  2. You can use Lightburn’s Machine Settings window to make sure the $32=1 is set (not zero). This tells the controller it is a laser and not a milling machine.
This troubleshooting guide may be helpful:
What should $32 be set to ? When I connect my long mill it connects to grblHAL. these are the settings i have set right now
$30=255.000
$31=0.000
$32=1
$33=1000.0
=1, which I pointed out above.
$30 is normally set to 1000 in the newer controllers. Make sure Lightburn matches S-value max in the Device Settings window.
