My laser suddenly stopped responding, I can not frame or fire the laser. It was working fine a few minutes ago
try a power cycle of both, laser and PC
Tried that a few times, no luck
check with a tester if power supply gives you the correct V in output
  • Do you get any error messages in the console window?
  • Is it plugged in and turned on?
  • Is the emergency stop button pressed?
  • Are the lights on the board lit up?
When you say “it’s not working” that isn’t much to go on. Give us as much detail as you can about what it is doing, and that will help people help you.
So I got it to start responding and its firing correctly now. For some reason the Start From position changed and that was the issue.
