I recently set up my Snapmaker Ray 40W laser machine and configured the initial work area to X = 600 mm and Y = 400 mm. However, whenever I start a laser job, the laser head attempts to move beyond these boundaries. As a result, it crashes into the machine’s edges and triggers a limit switch warning.
At the moment, I’m unable to use the machine in automatic mode. I have to manually move the laser head to the desired cutting position before each job, which is quite inconvenient.
Could you please assist me in correcting the machine settings so that the laser operates properly within the defined work area?
The machine waits in the top-left corner in home mode. When I fill the 600 × 400 mm area in LightBurn and try to start the job, it gives a limit switch warning. So I definitely can’t use the full working area. I’m sure I entered the X and Y values correctly. I would appreciate it if you could explain the steps I need to follow in more detail, as this is my first time using such a machine. Thank you in advance.
