Homing
ALARM:9
ok
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [’$’ for help]
[MSG:Check Limits]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
Homing
ALARM:9
ok
OLF 137.
[MSG:Check Limits]
“ALARM:9” : _(“Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.”),
Check that all the cable connections are correct. @OrturTech - any suggestions here?
Thanks, my cable was not correct. everything worked fine but the lase didn’t fire up, showing alarm: 3 error.
Greetings @SACHIN
Could you please post a few pictures of your wiring (Near the limit switches as well as the pin board please)
Also could you verify if - with machine unplugged - and you move your gantry to x0,y0 both switches are reachable and click?
Hi,
thank you for your response, my laser master is not firing. and sending you the video link as well.
Could you please just attach a final picture of the wiring here in this angle please?
Showing the wires going up. The black casing is hiding the wiring at that point
Thank you
All seems correct. Inquiring with engeneers.
Final question if i may. WHen you turn machine on, does it do the homing procedure correctly?
hi, yes when i turn it on it comes to the home position to the left corner. i’m sending you the video link as well. https://vimeo.com/443075348
What speed settings and power settings are you trying to run at?
_____ mm/min and ___%?
