Hi I’m new to all this I have two CNCs but first time with a laser. I’m using Lightburn and I think its setup right. When I turn it on it homes to the left front corner, But it says its disconnected under Laser in Lightburn. Can someone tell me how to get it connected? Thanks Tim
Have you selected the apropriate COM port here?
If you’re on a MAC I found that mine will not recognize the laser if I turn it on before I launch Lightburn. Just a thought. Good luck.
For the next release, I’ve made this more obvious - If you only have one port that matches the connection criteria, it will connect, whether we generally support “auto connect” on that device or not. If you don’t choose a port, and it doesn’t choose one for you, it will actually give you an error message directing you to do so if you click ‘Start’.
No I didn’t, thanks a lot got it up and running, I never did turn that com port on! Thanks again!
